Rubik's Cube Solving Robot icon Rubik's Cube Solving Robot — Control a custom ARC robot to manipulate and solve a Rubik's Cube using calibrated arms and grippers; integrates with Thingiverse build. Try it →
Sorry dude, the ezb4 is wifi only.... However, you can connect directly to the ezb4 with your laptop or PC without using a router. You don't need Bluetooth to do this... However, your pc will obviously need to be equipped with wifi. If not you can buy a cheap wifi usb dongle off of eBay....
This question has nothing to do with the tags that has been selected for the question. Please use correct tags to maintain good standing of your account.
The ezrobot controller does not require an Internet connection.
O ok that good then It's been driving me nuts trying to figure out if it needed Internet and o I'm sry I'm new to the forum I thought I was suppost to pick the boxs that the subjects related to my bad, I will be carefully next time to pick the one most relatevant. Thank you for Your reply and my most sincere apologies.
:) it's all good.
When you select a tag/subject, different things happen. For example, you had selected your post as a tutorial - this means your message was sent out as a tutorial to Twitter. It will also be flagged as a tutorial for your account.
