Iron Man Jarvis Ez-Robot Recreation Scripting Questions
Hi.
quick questions for scripting.
  1. Is there a command that says "if __________ is said(microphone), start this script."?
  2. Is there a way to say "if this script starts, do this."?
I'm not sure cause I still don't have the ez-b yet,(By monday:) ) but if your speech recognition is good and, if I'm not mistaken, you can call/assign any function you want to the command. So you would have to make a function with the if statements in it. So it depends on what your checking. I imagine you can do something like if servo is at x position do whatever. Or maybe even, depending on your set up something like if distance is x do something. and the details all depend on your setup but that would be the logic to the problem. Someone will have to verify that.
That's why I bought the ez-complete. It's programming seems pretty simple but incredibly powerful. I can't wait to start testing all of my theories and questions out.
And well, let's be honest, for being my into to robotics kit it is power packed for the price. I could have easily spent $300-$600 on something half as capable.
Dude, you should know this already:)
Voice recognition control, add the phrase i.e. "robot dance" and add the command ControlCommand( "Script Manager", ScriptStart, "MyScript" ) to start a script
And the same for when a script starts, have the first line as a ControlCommand too.
You could also use the WaitForSpeech( timeOut Seconds, phrases ) command in a script, but the VR control is a much better way. WaitForSpeech is good for confirmation of command though. I'm pretty sure there are some speech confirmation scripts in the forum.
A quick example of voice activated control running a script is here (not the complete jarvis project I'm putting together just part of it)
And it does something like this...
ok so 1.Speech recognition "Jarvis test rc car robotÈ
ControlCommand(ÈRc Car", scriptstart)
2.IF controlCommand(ÈRc CarÈ, scriptstart) Controlcommand(ÈLight TestÈ, scriptstart) ENDIF
Sorry, having a brain fart moment.
Im not 100% on the code so I may be misunderstanding but. 2. IF (get servo position, or get distance, or get what ever reading you need from your sensors) = or<or>(what ever operator you need) what ever your parameter is. Do something.
So as an example (My pseudo code, not ez script, you'll have to port it yourself. I'm trying to mix english and code so it makes sense.)
Assuming that 2. is the code for the function you are calling.
2. IF sevo.d1.position = 45 (Then? does ezb use if then or just if?) servo.d2.position=45 ENDIF
So, that says, if servo.d1(RightArm) is at position 45 then move servo.d2(LeftArm) to position 45. I've read enough of your posts to know that you know what I'm trying to show you. The mail came and went so no ezb till monday. So while I'm not experienced in EZScript, it seems to be an object oriented language. And I have yet to meet an OOL that I haven't been able to talk to ;-)
As far as OOL programing goes, the phrase "I walked the dog." means "I walked the dog." in any language you say it. (I wish human languages were as simple.) It's usually a matter of getting a syntax reference. The concept of programming is the same, you just have to think in things in terms of a language you already understand and then just look up the equivalent in the language you need to use. All of the OOL have fairly similar commands. One thing that gets people is the End Of Line or more to the point, what I call End Of Phrase.
Some languages simply treat a newline [Enter] as the end of a line of code or phrase. Others require the semicolon ( ; ) . Some languages use If () then {}, some use just, if(){}. () being where conditions go, and {} being where the code goes. I'm pretty sure when it comes to arrays, that ALL languages start at 0. You always have to be mindful of what I call 0 based returns and 1 based returns. Arrays start at 0. But Array.Count() in most languages starts at 1. So if you use Array.Count, it returns 5. But if you call or reference Array[5] it could error because, it is beyond the scope of Array. "It said I have 5 items in the Array." Yes, 0-4 is five items. So to call or reference the 5th Array object you'd use Array[4]. I said could error because you can define a max length of an Array and some languages fill the spots as some sort of "existing but empty" so it may throw an error while some languages see them all as "non-existent" or "undefined" and that would throw an error.
It may sound trivial but if you plan to explore multiple programming languages, especially object oriented, things like that are gonna be the best place to start looking when you go to porting code or learning a new language. They really are all very similar. OOL seems to be the current standard. I've never touched "C" and only dabbled very minimally in "C++". I've never had to use them to do anything I've ever wanted to do. But then I've never tried to start building robots till now ;-)
The first computer I owned, was a Commodore 128, back when I was about your age. I learned basic, where a novella's worth of code got a balloon to scroll across a monochrome screen. Oh the good old days of no-def computing. But I digress, Then I got into HTML and web design. Which led to JavaScript and PHP (I've always been a big fan of PHP.) Which lead to SQL, MySql. And then I was just sor of known as the computer guy. Alot of my skills after that came from people saying, "I'll give you $XX - $XXXX if you can do this for me." And I'd tell them up front that I don't know how long it would take, ask them if they had any language requirements, and a no money back lack of guarantee. Then they would say "Shut the hell up, you know you can do that sh*t."
I've always been more integrated in being able to do stuff, not getting paid to do stuff. Now that I'm older I sure do appreciate being paid, but I love to learn stuff and share what I've learned. That's what computers were about when I was your age. I've helped a few small businesses get off the ground. One folded, one screwed me. Quick lesson, when it comes to money, get a contract. I learned the hard way. But I'm not upset. That code is all super old now. It's not like they turned into a million dollar company off of my code. (I hope their still not using that old code, my lord. It was a rats nest).
You seem to have an aptitude towards this. I've no doubts that if you pursue your robotics interests the rest of your life you will make the world a better place or be solely responsible for the end of it. ;-)
Thanks Antron007. Your right. I'm the "Techno Geek" at my school with the teachers always asking for help. I also deal with being 6ft tall(I've got a tough life).
With my coding, I could use variables and each script sets off a variable.
Sorry, I've been out all day... it's too late and I've been driving for far too long to read all of that but here is what you want to know (I think)...
To start another script when one is started you can just add ControlCommand( "Script Manager", ScriptStart, "MyScript" ) at the start. So you set up voice recognition.
Phrase: "Jarvis test rc car robot"
ControlCommand( &quot;Script Manager&quot;, ScriptStart, &quot;RCCarTest&quot; )
Then at the start of the RCCarTest script you add in
ControlCommand( &quot;Script Manager&quot;, ScriptStart, &quot;AnotherScript&quot; )
Or you could do it a different way... At the start of the first script, in this case RCCarTest you add in a variable so that ARC knows it's started...
$RCCarTestRunning = 1
Whenever the script can stop running add the following before where it stops
$RCCarTestRunning = 0
In your other script you use a WaitForChange() command and an IF (the IF may not be required but it makes it more accurate).
:wait
WaitForChange($RCCarTestRunning)
If($RCCarTestRunning = 1)
  # Run the script
  Goto(startscript)
ElseIf($RCCarTestRunning = 0)
  # Don't run the script jump back up before the waitforchange
  Goto(wait)
EndIf
:startscript
Or you could just let it loop around the :wait part, but this will use up more resources.
You could also use WaitForServoMove(servoport), Servo_Wait(digital port, higher/lower/equals, value), Digital_Wait(digitalport, on/off/true/false), ADC_Wait(adcport,higher/lower/equals, value), ADC_Wait_Between(adcport, low, high)... and a few more, just type in wait in the search box to the right of the script box to see all of those options.
@rich- most of it was my version of programming theory 101. I can't wait to get my kit so I can start playing with all of ezb's code.
