Interface Builder icon Interface Builder — Create touchscreen robot control panels with buttons, joysticks, sliders, camera views and scripts; multi-page fullscreen UIs for PC and mobile. Try it →
I2c Camera Module
I2c Camera Module
Would it be possible to use an i2c camera module with EZB v3 or v4.? I found this on Ebay..640x480 VGA CMOS Camera Module OV7670 FIFO Buffer AL422B SCCB compatible wit I2C
$13.90
High sensitivity for low-light operation. Low operating voltage for embedded application. Standard SCCB interface compatible with I2C interface. With AL422 3M-Bits FIFO. Raw RGB, RGB (GRB4:2:2, RGB565/555/444),YUV(4:2:2) and YCbCr(4:2:2)output format. Support VGA, CIF and from CIF to 40 x 30 format . Vario Pixel method for sub-sampling. Auto Image Control: AEC, AGC, AWB, ABF, ABLC. Image Quality Control: Color saturation, hue, gamma, sharpness and anti-blooming. ISP includes noise reduction and defect correction. Support image scaling. Lens shading correction. Flicker 50/60Hz auto detection. Color saturation level auto adjust. Edge enhancement level auto adjust. De-noise level auto adjust Photosensitive Array: 640 x 480. IO Voltage: 2.5V to 3.0V. Operating Power: 60mW/15fpsVGAYUV. Sleeping Mode: <20A. Operating Temperature: -30 to 70 deg C. Output Format: YUV/YCbCr4:2:2 RGB565/555/444 GRB4:2:2 Raw RGB Data (8 digit). Lens Size: 1/6". Vision Angle: 25 degree. Max. Frame Rate: 30fps VGA. Sensitivity: 1.3V / (Lux-sec). Signal to Noise Ratio: 46 dB. Dynamic Range: 52 dB. Browse Mode: By row. Electronic Exposure: 1 to 510 row. Pixel Coverage: 3.6m x 3.6m. Duck Current:: 12 mV/s at 60?. PCB Size (L x W): Approx. 1.4 x 1.4 inch / 3.5 x 3.5 cm
VGA OV7670 Camera Module x1
No. You can use the ezrobot camera though.
There's no way to get the video from the ezb-b translated and into ARC.
Thanks DJ and Technopro for fast response...
I2c is too slow as well. It's max speed is only a few hundred hz which will only give you a few frames a second anyway
