Websocket Client icon Websocket Client — WebSocket client for ARC: open/send messages, store server responses in a variable, run a response script, and track connection status. Try it →
I2C Device Voltage Question
Is it possible to connect an I2C device to the EZB v4/2 with just the SDA and the SCL lines connected with the device its self getting its voltage from a higher voltage source (Greater than 3.3v)?
If you share the grounds. Common grounds are necessary for reference voltage.
Yup of course! Great thanks!
Always good to think of ground as the actual ground. And voltage as how high you can reach. If we stand next to each other on the ground, one of us can reach higher (or have higher voltage) than the other.
so ground is always a reference to know the amount of voltage. Ground is also super important because if it’s not shared, or has resistance, the voltage can actually be higher - and release magic smoke.
amazing how important a common ground is. And how simple of a thing it is if it’s explained in the correct example
Great explanation!
