Inverted Pendulum icon Inverted Pendulum — Balancing controller for Sainsmart v3 (and compatible) robots: PID tuning, real‑time telemetry, angle offset, movement and calibration via ARC. Try it →
What is the correlation between a wireless USB hub and wanting to make your robot talk? = confussed
If you explain to us what your intent is, we might be able to help with better solutions.
Dj talks about the hub in speech also a sound card but I cant find any more info.He mentions an e bay 1.99$ sound card also . I found that but not the hub.:)
I assume he plans to use a USB soundcard inside the robot?
However, I would go a different route and use a wireless speaker. Bluetooth would be perfect as you will already have a bluetooth enabled PC running the EZB.
I'm using this bluetooth speaker from Target. It's compact, simple to use, and has better sound than what I was expecting.
Thank you that would work better.I will look for one.
See. I knew folks would be able to give you a good solution if they knew exactly what you were attempting to do:)
"I love it when a plan comes together!" (Tell me whose quote that belongs too...)
