Indoor Positioning System icon Indoor Positioning System — Infrared indoor positioning for ARC robots: dual-camera tracks IR beacon, shows real-time heading, path and EZ-Script navigation variables Try it →
it will start EZB builder and your program
Completely unnecessary.
Use the shortcut creator in ARC. Add the shortcut to the startup folder in Windows if you want autostart on boot.
It really is that simple.
thats what i did ,i used ezb builder start script,its just another way to do it some programs wont take .ink file like shortcut file,but will take a exe file this is what i used to make a auto load exe file
Auto Load Project: The ARC.exe accepts a few parameters.
  • Param 1: Path and Filename of project to load
  • Param 2: Name of Script to start when project is loaded
Here is an example of loading a project on startup:
"C:\Program Files (x86)\ ARC\ARC.exe" "C:\My Documents\MyFile.ezb"
Here is an example of loading a project on startup and execute a script named InitScript
"C:\Program Files (x86)\ ARC\ARC.exe" "C:\My Documents\MyFile.ezb" "InitScript"
also sometimes a bat file is needed too,when a shortcut cant be used SHORTCUT is good when you start your computer,but if using another program its hard
Also with a BAT FILE you can run 1 to 5 AND MORE of the EZB BUILDER programs at once,and set for min or max display shortcut creater only can make and run one ,unless you majke many shortcut files and place in your startup file
You also should avoid using paths such as "C:\Program Files" or "C:\My Documets" as these are variables in Windows and users are free to change the absolute path. %userdata% and %Program Files (x86)% or %Program Files% using IF EXISTS and ELSE should be used.
Batch files are very old hat and I hate to say it but yours is very sloppy. It will not work for everyone.
The .lnk file issue is irrelevant as ARC and Windows both support the shortcut both in the StartUp and from anywhere in the windows environment.
Why are you running 5 ARC instances? One instance will connect to 5 EZBs and control 5 EZBs. Running 5 of the same application will slow the system down considerably. However, there's no problem having 5 shortcuts in StartUp and Shortcut Creator can make as many as you require.
I wouldn't recommend using IExpress for many different reasons but the main one is, it isn't required for starting ARC projects.
@RichMR2
Not disagreeing with anything you said, but there is at least one reason to have multiple instances running on one computer, and that is that you can only have one Movement Panel per ARC instance, and some might want to control more than one robot from the same computer. Can be solved with scripting, but easier with separate instances per bot.
Everything else was spot on (sorry @robotmaker, but don't see the point of your app, and it doesn't use best practices...)
Just something easy and it works for me and using DJ AUTO LOAD example ,making a bat file you can do a lot more if needed like resize and more with the right commands,also can load other programs where on the shortcut creater cant.
ON the shortcut creater .i use on a robot when i start my computer it works fine.
when i tried with another software it doesnt,using LISPWORKS it says it cant use .ink file ,needs to be .exe mine is just a super simple example ,not made for most of us
ok guys... maybe it's one of these days when I spent too much time working on one of my projects but for what regards my installation of ARC, there's no such a thing as ShortCut Creator feature...
The manual says this :
How To Add This Control To Your Project Step #1) Load the most recent release of ARC Step #2) Press the Project tab from the top menu bar of ARC Step #3) Press Add Control from the button ribbon bar of ARC Step #4) Choose the General category tab Step #5) Press the Shortcut Creator icon to add the control to your project
And here what I see when I follow these instructions:
