Kondo KRS ICS Servos icon Kondo KRS ICS Servos — Control Kondo KRS ICS2/3.5 servos via EZ-B UART; experimental, untested. Supports chaining, virtual servo ports, Release() and Servo() commands. Try it →
How To Automatically Skip 'Update Release' Message On ARC Loading?
How can I automatically skip the 'Update Release' message when ARC is loading up, I'm running Auto scripts on a Latte Panda to run a project from power up, and want to auto connect from power up, without having to manually click to skip the Update release message?
I try to have the latest release, but as the releases are changing so frequently at the moment, every time I update a new one gets released, and its such a pain updating on my 32Gb Latte Panda, as I'm doing it on a 7" touch screen on my InMoov.
Beta version doesn’t have a skip option because it’s beta:)
stable ARC should be out by end of the month
#2   — Edited
Ps, because ARC is beta - the updates fix a ton of bugs, so it’s recommended to click the button to update:) . The computer does most of the work. Click click!
Thanks DJ,
I have the 32gb Latte Panda and for some reason I have to almost delete everything off it to make space every time I do a ARC release update, not sure why as it shows more than enough space available for the release update, but it won’t allow me to do the update until I delete files. It’s very fiddling doing on a 7" touch screen!!:(
TightVNC is your hero for using the panda on a touch screen lol
as for space - have you installed Windows N? It’s tiny! I installed it on my atomic pi. So much smaller than windows home
it’s called windows home N. It comes with the windows installer
Thanks DJ I haven’t tried Windows N.
I’ll have a go!
