On Variable Changed icon On Variable Changed — Run scripts automatically when specified ARC variables change; define variable-to-script pairs, monitor status, and trigger actions. Try it →
How To Remove Yellowing From A Robot
does anyone know how to remove the yellowing on my plastic on my robot i know about using bleach or white spray paint but here is the problem.like on a R2-D2 robot it has silver paint,blue paint ,plus other colors,plus in very small detail.but yet on sme pieces have yellowing of the plastic so can paint or bleach
so is bleach or painting it and then repaint the details with the right colors after it dries the only way or just leave it alone i did see info on a thread after i wrote this about retrobright ,will try it and post results i will have to borrow my lepard gecko lizard UV lamp
I have an Omnibot 2000 that I am considering restoring. I've been doing research on retrobrite so I would like to clarify one thing.
The retrobrite wiki recommends using hydrogen peroxide in a 10% to 15% concentration. The stuff in pharmacies and drug stores that is labeled "hydrogen peroxide" is typically only a 3% concentration, which is why it may not have worked well. "40 volume developer" is just the name hairstylists use for 12% hydrogen peroxide. Here is a good reference I found:
https://www.using-hydrogen-peroxide.com/hairdressing-peroxide.html
So I'm not sure it's accurate to say retrobrite does not work well. It does, but you have to use a higher concentration of hydrogen peroxide than is commonly available under that name. One place to get it is from a hairstylist, but in hairstylist lingo it is called "40 volume liquid developer", presumably because women would freak out if they thought they were getting "hydrogen peroxide" on their hair:)
The reason why retro bright does not work well is because the hydrogen peroxide evaporates from the developer over time and becomes less effective , also in direct sunlight the liquid can completely evaporate. So you generally want to keep the surface of parts wet with fresh solutions. After trying different methods I found direct sunlight and apply the solution every 45 minutes yielded the fastest results.
Did you use the gel formulation? (with xantham gum and glycerin?) I was thinking of going with that but I've yet to gather all the ingredients (plus, it's been fairly cloudy lately)
What was your experience in disassembling the Omnibot? I'm a bit wary in doing so; I don't want to end up with a bright and shiny, but non-functional robot:)
from what i found out that retobrite works better then the hair salon developer,but only if you use 40% hyrodogen peroxide hair salon i need to add more then a few times and other little less only problem is making it or buying all ready made,but making will save you money
Fred, AS I said before, the Green Cleaner from your local walmart or kmart will do the job. You want the one that is made from orange peelings. When I was working as a technician, we used it all the time and we got computers in that were horribly stained from smoke and kitchen grease. A little green cleaner on them, and they like they just came off of the assembly line. I don't know the Exact name, but if you check around I am sure that you will find it.
Mel
OK, the one I use is called BIO-GreenClean. It is $65 a gal. But,a gallon last a long time because you only use a teaspoon or two to make 32 oz of cleaner. You can buy it Ready to use for $14 per 32 oz. It goes a long long way. They are also products called SIMPLE GREEN. The trick is to find one made with orange peelings. You apply it, let it set for about a minute and wipe it off. Everything looks like new. It is BIO-degradable and is all natural and smells fresh and clean. No harmful chemicals, just orange peels.
I have used it for over 20 years.
My boss had a man that came door to door and sold it. it was $65 a gal. But, my boss hassled him down to only $8 a gal. It lasted for years using it every day on the workbench. That was a while back, so it might be more now.
Mel
#16
Yellowing is ultraviolet degradation of the plastics surface , it is not simply a stain that can be washed off with a cleaner. I realize some of these bots are really dirty. I put all my bots parts in the dish washer. To answer the guys question about taking them apart. It's easy , just keep plastic bags , a camera and sharpie available. There are small parts you want to save for when you put it back together.
