Hello, I would like to gradually increase and lower the value of PWM. Does anyone know how to do? thank you
reaktor
France
— Edited
Synbot Plugin
— Synbot plugin for ARC: local Bot Server chatbot integration with SIML dialogs, ControlCommand API, multi-language, learning and emotion support.
You could script it quite easily.
Apologies if the code is a bit messy and not explained too well I'm strapped for time but it should give an idea (hopefully)
Ok, I understand how the code works. Now it's clear. Thanks
Or you can servospeed() command. It applies to PWM as well
for example
Even I learn something new from time to time, I did not know ServoSpeed() applied to PWM too, that's much easier
