Hello everyone!
I am wondering what is maximum number of robots connected to the ARC at the same time?
I tried to look for the answer in the learn sections, but didn't find one.
Thanks!
:D
Feetech Serial Bus Servo
— Control Feetech SC serial bus smart servos via EZB UART or PC COM port with ARC virtual ports, speed, position, release, and acceleration.
Hello everyone!
Thanks!
:D
you will need to setup a bigger private network
https://en.wikipedia.org/wiki/Private_network
Some examples:
192.168.0.0/255.255.0.0 = (65536 - 2) hosts
or if you want to go BIG!
10.0.0.0/255.0.0.0 = (16,777,216 - 2) hosts
but other issues will surface, router support, wifi congestion...
if someone creates a project like that deserves a prize no ?
Hi @Alan @thetechguru (Sorry for not knwoing your username. It's kind of confusing)
Why only one can have the movement panel?
I was wondering why is the number 249 or 256? Are these numbers the restrictions set by the ARC?
Also @ptp I think what you said was just for the case that everything is under one private network.
What if all the ezbs are in client mode with different network? Say I have one ARC installed in one PC, and I want it to remotely connect with ezbs from outside.
Thus, I believe the restrictions are only from the ARC itself, the system where the ARC is running, and the bandwidth of it.
Right?
@Robocen,
You can have:
Multiple ARC's instances running on the same machine.
260 x EZB controllers per ARC's project
Each EZB controller (Client Mode) on a different network, as long as both ends ARC and the EZB are able to communicate.
Check this thread (DJ's justification post #6):
https://synthiam.com/Community/Questions/9482
