Continuous Servo icon Continuous Servo — Control a 3-wire continuous 360-degree servo in ARC: adjustable forward/reverse speeds, start/stop buttons, board/port selection and test controls Try it →
What's the code? GetPing isn't a command as such, it must be assigned to a variable, used in an IF statement etc.
I can confirm GetPing() works in the latest version of ARC. Check the EZ-Script help on the right of the EZ-Script dialogue.
I did. I copied it from there and I still get this.
Paste your code you are trying to use. Although it seems you are not assigning it to a variable or using it in an IF statement.
If you code looks like this
GetPing(d0,d1)
then it is incorrect.
GetPing (and any of the "Get" functions) must be used as part of something bigger, for instnace;
$ping=GetPing(d0,d1)
$random=GetRandom(0,100)
If (GetADC(ADC0) < 100)
Finished the code and get this error. Block directions - Start Block directions - Error on line 3: Missing String Quotes or Invalid Expression: < Block directions - Done (00:00:00.0156001)
Script:
#Check Left
If (GetPing(d0, d1)=<20)
$Noleft=1
EndIF
#check Forward
If GetPing(d2, d3)=<30)
$Noforward=1
Endif
#Check Right
If (Getping(d4, d5)=<20)
$Noright=1
Endif
This is just a practice script. Plan on doing a lot more work with it.
Your problem lies with the if statement. It should be <= not =<
You're also missing the open bracket on the second IF.
You will find this code works;
#Check Left
If (GetPing(d0,d1) <= 20)
$Noleft=1
EndIF
#check Forward
If (GetPing(d2,d3) <= 30)
$Noforward=1
Endif
#Check Right
If (Getping(d4,d5) <= 20)
$Noright=1
Endif
Also you really don't need to use the = sign in your if statements here. The less than sign is sufficient... the ping return is so varied that it will rarely ever equal any variable/Constant you may have set anyway...
You can also replace the = part by increasing the < by 1. <= 20 is the same thing as <21.
Personally I always use the <= but it's personal preference.
