EZ-B V4 Info icon EZ-B V4 Info — Displays EZ-B v4 internal temperature and battery voltage, shows built-in battery monitor and LiPo protection settings in Connection Control. Try it →
Hi RichardZ,
Were the two EZ-Bs placed into the exact same application? What is usually connected to D12-D23? How are you testing these ports?
You could try taking the EZ-Bv4 enclosure off and re-seating the WiFi board on the main board. Separate the two boards and them put them back together, just like in this video:
Jeremie, Sorry for the delay in responding, I was at a county fair showing my Inmoov as a static display. Both EZB's are in the same Inmoov. But the second EZB ports stopped working before I put it in the Inmoov. The InMoov is powered by a 60 amp Dell Server Power Supply. I take the 12v from the power supply and that powers both EZB's. The 12v also goes to 2 - 25 amp 6v regulators that supply power to ALL servos. All grounds are tied together.
I have tried reseating the communications board on both.
RichardZ
Hi again RichardZ,
To test each port you could make a new program and hook up an LED to Ports D12-23 and send a simple signal like a digital high and low? (Just make sure you have the LED cathode to Gnd and Anode to the digital port)
Do you own a mulitmeter? You could use that as well to see if there is a signal at the Digital ports or if power it's getting to the D12-23 Red power pins.
Yes, I have a good multimeter. I will do the high/low test first and depending on how that turns out, I will compare D12-D23 sinewave output to a working port with my O'scope.
I will post my results.
using the following basic code, I checked each port and had no change on the white (data) pin. 0v
:loop
set(D12,off)
set(D13,off)
set(D14,off)
set(D15,off)
set(D16,off)
set(D17,off)
set(D18,off)
set(D19,off)
set(D20,off)
set(D21,off)
set(D22,off)
set(D23,off)
Sleep(1000)
set(D12,on)
set(D13,on)
set(D14,on)
set(D15,on)
set(D16,on)
set(D17,on)
set(D18,on)
set(D19,on)
set(D20,on)
set(D21,on)
set(D22,on)
set(D23,on)
Sleep(1000)
goto(loop)
What was connected to those ports?
805BB Servos, and drew power from a separate buss not thru the EZB.
@rz90208 I could be wrong but I thing @DJ means what was attached to those ports when you did your set(D12,ON) tests....
