Get Line Containing From Array icon Get Line Containing From Array — Adds GetLineContainingFromArray() ez-script function to return the first array item that contains specified text, simplifying substring searches. Try it →
Ezb Controlled Lynxmotion Johnny Five Robot
I made a johnny five robot from lynxmotion and made many changes ,upgraded to higher torque servo's,added another deck for itx board,change the motors for higher torque,looking to add feedback,plus more servo's in arms ,plus web cam and more
Most of this is done already,was going to use lynxmotion SSC-32 servo board until i found the best controller for it EZB
BIGGEST problem finding a small ITX to replace my pico-itx board at 1 ghz 2 gig ram
here is a photo of the design without changes
will be posting photos of it with changes,it a little apart for more upgrades kit is about $900 and to add very high torque servo's about $1300 like i did 16 servo's now and might add 2 more for drive
#41
I just have boxes in different rooms ,and it whas in my large storage shed 15 feet by 40 feet
#44
Is this last picture yours?
#45
both are ,i took both about 30 min ago one is my hand design as you can see it has a few changes and second has a lot of changes too
#46
i guess the hand part you cant see it has 3 fingers like JOHNNY 5 has
#47
NECK part looks to be the hardest,for some of the custom pivot points ,and for air cylinders They have 2 types one to make the head tilt side to side and another to tilt up and down besides rotate.
That milling machine i bought will come in handy for that,might use stock plastic bar or stock aluminium bar to make the mounts.
this photo is part of what i need to do
and here is the second part of the neck
Amazing and thanks for the updates robotmaker!
