United Arab Emr
preparing for the big Event:)
DJ responded to a similar question earlier, if no movement is detected they turn off to save bandwidth, no point watching a camera showing nothing going on.
ok that make sense. So pumped to watch the presentation!
ITS WORKING NOW,i see they put the the food out,dont see any pretty ladies like DJ's secretary.
I'll be sleeping during the presentation:( It's like the middle of the night over here when that happens...
Looks like the cameras are back and a bit of a shift around with furniture:)
Why need sleep,robots are more fun to build then sleeping.
yea noticed that. for some reason it says the last post was made by robot_maker, but he's not even on this topic.
I expect he is, but he was made into a ghost user when the site got it's upgrade. If you read the site rules it explains ghost users. Basically a ghost user is one whose posts are not displayed by default due to a number of factors, disruption, breaking rules, abusiveness etc. you get the idea. You must manually set your settings to display these users posts since, well, there is good reason for them to be hidden. Enable them at your own discretion but remember most users will not see the posts so if you reply it may look odd. In many cases it's also wise to take those ghosted posts with a pinch of salt.
