Websocket Server icon Websocket Server — WebSocket server for ARC: accepts clients, stores messages, runs per-message scripts, tracks connection status, supports debug, needs Windows admin Try it →
Ez-B V4/2 Pcb Cad Layout
Hello everyone, I am looking for a cad file for the EZ-B v4/2 pcb. I am specifically looking for the dimensions and mount hole locations. An stl file isn't useful.
I want to make up a bracket to fit the EZ-B v4/2 board into the head of my Inmoov "T-One"
I just measured mine with calipers and knocked up a design in Autodesk 123D. The CAD files would make it easier but I had no issues just measuring the board...
Yes, I was being lazy. I had seen that cad files were available on the EZ-B v4/2 product page but it was just stl files for the case. I've made up dozens and dozens and dozens of files for the 3D printers I have designed and built but like I said, just being lazy.
Did you want to share your design Richard? I use fusion360 so it would convert easily from autodesk123.
Use the learn section, select the product, and view the datasheet
Or
Select the 3D printing sub menu in the community section of this website. Look at the designer resources
