I have the camera up. I am using the EZb robot example for Wall-E I starty this face recontion script Wall-e gets into potion but the camera does not lock After a few seconds scripts end nothing else happens
Is there a calibration or something?
Waveshare Bus Servos
— Control Waveshare servos (TTL/RS485): set position & speed, release torque, read position. RTS option for converters; reverse-engineered protocol.
Which Wall-E example? There are 4 of them.
Edit: If Wall-E Big, then the script will run and end. The script moves 4 servos in to position and then also enables servo tracking and face tracking on the camera and disables movement tracking. Check it has done it by clicking on the tracking tab of the camera control, you should see face is ticked.
Then it will follow a face once detected.
Thanks Rich
Yes that is the one I am using.
