Hi my camera charges but the blue light doesn't turn on any more can any one help Thanks
wall e lover 360
— Edited
5 Participants
Joystick (Direct Input)
— DirectInput joystick control for ARC: drive movement panels, control servos, assign button scripts, variable speed and rumble feedback.
Try reading the battery voltage. If it's not charging you may need another battery.
There is the option of external power mod , are you sure the charger is functional?
Could it be that it's not turning on due to how long you hold the On button? The camera is very touchy as to how long you need to hold the power button to turn it on. Usually it only takes 2 seconds of holding it in to turn it on but some take a little more. Experiment with how long you hold the button down an see if you can get it to turn on.
Adding to what Dave suggested try using a usb phone charger to charge it , maybe the charger got zapped by a surge or something.
well my camera is hardwiered in so shuden it not need to charge but it is chareged
I changed my picture and my user name now it looks like this
@wall-e lover 360 ... Dude you need to re-write this sentence "well my camera is hardwiered in so shuden it not need to charge but it is charged", because I have no idea what you are saying.... confused
When I hardwired my camera, I totally removed the battery.
