Script icon Script — Multi-language ARC Script: build, run and debug Blockly, JavaScript, EZ-Script or Python with Intellisense, run/save/load and Roboscratch support Try it →
No WYSIWYG... You cannot use any other camera directly through the ezb itself ( other than the ezb camera)... If you want a better res camera you will need to buy one that works with your pc like the usb Microsoft lifecam....
Visit the manual for the camera control and read about image processing.
There is no ability to change the resolution of the ezb camera. Your option is to use a USB cam
The ezb camera is optimized for incredibly low latency (near real time) over wifi, which cannot be found in any other wifi camera. It is also optimized for auto color and saturation for image processing.
Welcome to ezrobot where you can begin learning what all that means:)
If you want a higher resolution camera for recording video, I recommend a go pro or something that doesn't have image processing.
