Prevent PC Sleep icon Prevent PC Sleep — Prevents a PC from entering sleep mode via a tiny, resizable control-keeps the system awake while minimizing UI real estate Try it →
Extended Range Wifi From Ezb?
So once the ezb v4 is inside the lawn mower bot it doesn't pick up as well, Any ideas on making an external antenna or adding a booster/ amp? I need the mower not to eat the neighbors cat , haha
The ezb antenna is actually better than an external antenna. We ran extensive tests with external options with poor results. The best results were with the onboard pcb antenna.
If you mount the ezb on the top of your robot, it will have less interference and grounding.
Look into the /2 upgrade option for onboard PC connectivity via USB.
Are you using the ezb as AP or Client mode ?
