My elbow on my JD Robot stopped working suddenly! All of a sudden it froze up! What do I do?! stress confused tired
Gunther
— Edited
Sabertooth Movement Panel
— Sabertooth movement panel: control two motors via Simplified Serial with variable speed sliders, movement buttons, and serial port options.
Check the wire from the servo connecting to the ezb. Make sure it's plugged in and the pins are not bent. If that doesn't work, you can swap it out with a new one from here: https://synthiam.com/Shop/AccessoriesDetails.aspx?prevCat=104&productNumber=1301
