I have order a Dual Axis Compass for my EZ-B. Please give me a wiring plan. Thank you very much
— Edited
Touch Path
— Sketch paths with finger or mouse and set turn/move speeds; interactive, educational demo of timing-based, sensorless robot navigation and limits.
Sure thing
Connect the SDA pin of the compass to the SDA of the i2c interface on EZ-B Connect the SCL pin of the compass to the SCL of the i2c interface on the EZ-B Connect the VCC pin of the compass to the +5 of the i2c interface on the EZ-B Connect the GND pin of the compass to the GND of the i2c interface on the EZ-B
I noticed the compass i2c is a little strange for wire distance. I kept my wires very short (less than 2 inches). If u make the wires longer, you may need additional pull-up resistors.
MovieMaker had used 10k ohm pull-up resistors: https://synthiam.com/Community/Questions/1303&page=2
Hope that helps
Hello DJ Thank you very much, do you mean with SDA and SCL (i2c) from the EZ-B the digital Ports D0-D19?
From the EZB I2C port
which is the I2C Port? see the Picture?
Top left of that picture I believe, the markings should read SCL, SDA, 5V & GND
Thanl you
The tutorial will help you. This is the link to the "Learn your EZ-B" step, it's a good one to know: https://synthiam.com/Tutorials/Default.aspx?id=2
Yes thats good, Thank you very much! Sven
