Hello,
I want to download the software to to an acer chromebook and having no success. The computer keeps on staying that I need to download an app in order to be able to use the software. Please help!
Arduinocoms
— EZB v4-Arduino I2C bridge for ARC: supports custom C# code and reads gamepad or Wii controller inputs for robot control
Hello,
EZB program requires the Windows 7 and above OS to function
@Kirzner.
As Robot-Doc has mentioned, you will need full Windows 7 or Windows 8 (not the mobile RT version of 8 though) to run ARC successfully. Here are the minimum requirements you will need...
Windows 7 minimum
Intel Pentium or AMD 64 or 32 Bit 1 GHz CPU
2 GB RAM
50 MB Drive space.
As @Doc says, you need a Windows 7 or 8 computer or an Android (to use the android version....). The Chrome OS is not supported....
android whit atleast firmwire 4.1
i use win8 home edition on a notebook.works really well. lesser problems then win7.
As Richard and nomad have correctly stated, you can use Andriod too, but you will need the ARC software on a PC first, to create a project. Then if you wanted too ,you can use an Android (and soon an iOS) device to access your project and control your robot.
I currently use Windows 7 on a laptop, and ARC works absolutely fine for me
. Do you have another PC you can download it on to? Also if you have another PC, you could use the ARC http server, then connect to that server through your Acer using it's web browser.
