Soundboard (EZB) icon Soundboard (EZB) — Play WAV/MP3 via EZ-B v4, manage tracks, add timed scripts for synced robot actions, control via ControlCommand(), volume and clipping indicators. Try it →
This is very simple to do. All you have to do is use an If statement. Example:
if getping() < #distance
Controlcommand("soundboard", Track_1)
Endif
This will run once and play a sound if the distance if at the set number. change #distance to the output of the ping sensor that is the distance you want.
assuming you have a Soundboard control added to your project
try this:
#Ping/HC-SCR04 sensor configuration:
#     D1 = trigger port
#     D2 = echo port
#safe distance in centimeters
$safe_distance = 50
:loop
        #wait for a distance lower than the safe_distance
	Ping_Wait( D1, D2, lower, $safe_distance)
	#play soundboard control track 0
	ControlCommand("Soundboard", Track_0)
	#wait for distance greater than the safe_distance
	#this will avoid multiple play sounds
	Ping_Wait( D1, D2, higher, $safe_distance)
Goto(loop)
@MazeHorizonTech you beat me in 6 seconds... not fair you are around the corner (Canada):)
@MazeHorizonTech
Missing:
  1. if parentheses
  2. Ping Ports
Something like this:
if (GetPing(D1, D2)<50)
endif
The easiest way...
Ping_Wait(D1,D2,LOWER, 15)
Mauritius
Thank you very much guys for helping:)
@ptp My bad. ARC didn't complain when I wrote it out in full interestingly.
If @nyyirsS uses Richards, all he has to do is add a loop if he wants it to repeatedly happen.
Mauritius
@MazeHorizonTech
All answers is good. I give credit to ptp bkoz he usues comments which makes me understand as I have no previous knowledge in ez script..
Still Thank you everyone for your help
