Speech Synthesis icon Speech Synthesis — Speak user-defined text via PC audio or EZ-B v4 speaker; configurable voices, effects and speed; uses Windows TTS; programmatically callable. Try it →
Dialogflow Skill Out of Date and Poorly Maintained
Dialogflow Skill Out Of Date And Poorly Maintained
I need to reimplement Dialogflow into my robot's ARC application. However, I can no longer find the api key field in Dialogflow as described in the most current tutorial of the most current version of the skill (version 19 as of this writing). In Dialgflow Essentials (which I am using currently), there is only a google project ID field now.
Clicking on this id, which is a link, takes me to the Dialogflow Project in the Google Cloud Platform. Now, here I can see some api keys, which I made sure to refresh.
However, none of these api keys will work when I insert them into the skill fields, no matter how long I wait for changes to take effect after refreshing them.
Furthermore, I'm disappointed in the help icon for the Dialogflow skill, as the help icon besides the API key field refers to the api-key for another skill (Microsoft Bing). I'm not sure what other mistakes might be in this skill now(?).
Note, all testing so far has been with the EZ-board turned off and my computer alone connected to the internet (I will ensure the computer is connected to my robot and the internet simultaneously later, of course, to use Dialogflow).
I kindly request this skill be updated and corrected where needed, unless there is something I am still doing wrong. I've been spending hours searching Synthiam.com, but have not found anything in the manual or tutorials, which all seem to be out of date for Dialogflow, from what I observe. I also cannot find any community posted questions related to this issue (which I find surprising; I thought someone would have seen this or had trouble with it by now). I'm even questioning, thus, if there was something I missed while trying to navigate synthiam.com--the site doesn't always feel intuitive to navigate for me. So if I did miss anything for the life of me, I'd appreciate any correction, but given what I know, see, and have tried, I've run out of options.
Dialogflow by Google
Add Google DialogFlow NLP to ARC: conversational intents, parameter prompts, scripted responses, service-account setup and programmatic robot control.
#1   — Edited
While I likely can't help much, I can mention that this skill is on the list to have its documentation updated.
For further questions, the author of the skill @DJ Sures may be able to help.
@presleyloren: When was the last time it worked for you ? I'm curious as to when it stopped working.
Any response on this issue?  I have not used DialogFlow before but was trying to install and ran into the same issues with API keys.
Were on it:) should have an update sometime in the next 2 weeks
Thank you, DJ Sures. I appreciate it. I suspect the code update should come very soon now?
Soon-ish. It's a bigger job than expected. The changes they made to the api isn't as flexible as the previous api. It's a huge pain to use their config interface to setup google authentifcation and such. Stay tuned
Just touching base. Any update on this?
