Total Speech Recognition icon Total Speech Recognition — Offline Windows speech recognition with open dictionary, confidence filtering, and scriptable phrase actions for ARC robots Try it →
DLL Assembly Resolve Plugin Error
I am trying to install the Rubik's Cube Solving Skill and I get a DLL Assembly Resolve plugin Error. I get "Does this plugin require and update?" I folowed the Synthiam directions for loading the skill, but it didn't work. How can I get this skill loaded? We are wanting to build one of these for our Robotics Club at the school. Thanks for any help you can give us. The next error that comes up says that ARC plugin and needs to be updated to ARC. Can you do this?
Control a custom ARC robot to manipulate and solve a Rubik's Cube using calibrated arms and grippers; integrates with Thingiverse build.
It sounds like you may need to update the plugin for the Rubik's Cube Solving Robot skill. You can do this by going to the "Add Controls" menu in ARC, selecting "Manage" and then selecting "Plugin Manager". From there, you can check for updates and update any plugins that need it. If that doesn't work, you can try uninstalling and reinstalling the plugin. If you continue to have issues, you can contact Synthiam support for further assistance.
This is still unresolved. The robot skill for solving the Rubik's Cube needs to be updated for ARC.
Hi @ Rio Makers, You're likely correct that the plugin likely needs some updates but you could try removing the plugins from your folder:
C:\ProgramData\ARC\Plugins
You could delete them all and redownload each one, or remove them all and store them in a temp folder for testing.
If that doesn't help you could send a message at the bottom of the Rubix cube skill pageasking for assistance, then the creator of that plugin will be notified.
You know what? It does look like the author has not updated this robot skill. I can look to see if there is a way i can update it for the required changes. But ideally, PTP (the author) would need to update it. Let me take a look later and see if there's something i can do for you
Thank you DJ. The Robotics Club kids would be very happy. They think it is cool!
