rr
i like the bottem one
Bearing in mind that if you remove and reverse servos on Six you will find most, if not all, stock actions will not work correctly. In some cases there could be a chance of servos clashing or moving beyond safe points.
While the reversing servo method will work it is not the ideal solution unless you are not planning to use any pre-made actions, frames, scripts, controls etc.
If you can't mentally work out what 180 less the servo position is I'd begin to question your ability to tie your own shoe laces to be honest, this is something my 5 year old nephew can do mentally in seconds (the math, not trying his shoe laces).
rich
thats i a good one.i went to a school for mentally slow and not smart, people.i cant help not being able to do simpel math. i can tie my shoe laces.we didn get to learn math. even if we did ,my mind wouldn understand it.
