SMTP Client icon SMTP Client Send SMTP email (text or camera images) from ARC robots via ControlCommand; configure SMTP/auth and sender; saves credentials in project. Try it →
Controlling Motors With Arduino Through Bluetooth Joystick
I'm trying to connect a Bluetooth joystick to an Arduino to control a differential drive robot through EZ-B. I've downloaded the firmware to Arduino and connected it to EZ-B... and added a joystick control through the Joystick interface but I'm not too sure how to connect the Bluetooth joystick. I have an HC05 module that I'm trying to connect to the Arduino UART but how would the handshake work through EZ-B?
Edit: After spending a few hours on here looking at similar questions, I'm even more confused. I'm going to ask a few questions and they might seem stupid, but I need to understand lol. Isn't ARC able to provide the controls for how I control a robot through differential steering (Continuous servo Panel)? Am I able to download this to my Arduino or does it have to be in conjunction with it (so PC attached to Arduino the whole time)? Am I able to use ARC controls with my Arduino untethered from the computer? The end product is (sorry for the run on) a robot with 2 wheels controlled by an Arduino that's using Continous servo Control from ARC through a Bluetooth joystick that connects with HC05 Bluetooth module or similar. The point is that I'm trying to take Arduino pins and attach to ESCs that control the motors the way a differential steering robot would be controlled. If i'm going completely the wrong route, someone please direct me =)
Program Arduino Uno with EZB firmware for Synthiam ARC control; pinouts, PWM pins and frequency details for Arduino boards.
USB
Servos 12
UART
ADC 6
Digital 14
DirectInput joystick control for ARC: drive movement panels, control servos, assign button scripts, variable speed and rumble feedback.
Control two continuous servos for bidirectional robot movement with speed sliders, configurable ports/stop values, testing and brake/coast options.
#10   — Edited
You are welcome elsayedm,
Ang
Czech Republic
hi DJ is there any chance in near future to connect joystick in mobile arc??? thanks
