HT16K33 Animator (8X8) icon HT16K33 Animator (8X8) — Control for Adafruit 8x8 LED Matrix (HT16K33) via EZ-B v4 I2C; creates animations, supports module initialization and EZ-Script control. Try it →
Are you talking about the advanced tab in the ezb4 web server? If so are you sure your ezb4 is an ezb4 x/2 version rather than the first gen EZB4? I believe the advances settings tab is only available for the second gen ezb4 x/2 version...
You don’t have ezb4.x/2, you have an ezb4.x/1 as shown in your connection log. The tutorial states that you require a minimum of a /2 communication board for that feature.
View the connection message in ARC - you can either catch the STAY checkbox in the debug popular window at the bottom -OR- manually add the debug control from Add Control
You can upgrade your ezbs to the latest communication module here: EZ-B v4/2 Comm Upgrade
Thank you gentlemen.
You are of course quite correct. I thought I had purchased v2's from Hobbyking but I must have made an assumption that they were the newer ones.
File this under human error.
I've ordered the update.:)
