NMS Navigation Data Grabber icon NMS Navigation Data Grabber — Query NMS lidar scan data by angle, with control commands for range, arc extremes, and obstacle checks from the latest scan. Try it →
Connecting To More Than One Camera
Now I have my second EZ-Kit and EZ-Camera I'm toying with the idea of using 2 cameras in my build, or possibly one PC using 2 cameras in 2 robots.
But, the problem seems to be that both show up as Windows Video Device in the dropdown when two are installed. I can select one of them and it'll work fine but selecting the other is not selectable (or at least when it's selected it jumps back to the first one and displays a black screen).
Both cameras display fine in AmCap so I know both cameras work.
Has anyone else tried this? And was it successfully?
I am interested in this too
I was able to run two Ez-Cameras in two ARC windows on my PC.
Two of the exact same camera? Two different cameras works fine, my issue is they both have the same name and it's as though ARC gets confused as to which is which.
Yes, two exact Ez-Cameras with Wireless Video Device, You have to have the first camera plug in first and on the first ARC than open up the second ARC than plug in the second EZ-Camera. Thats how I did it.
WILL have to try it,i need it for my johnny five project Will have to use 2 EZB witch i dont care for to much,but since i need a lot of digital prts and analog ports and multiplex design may not work for that project.
But might still use it since,i have 26 servo's plus using 16 analog ports and still using more then 12 digital ports and dont have the room first for a 3 EZB and speed will be a problem too
#15
I'll have to try that at some point but running 2 instances of ARC is not acceptable for my project, neither is having to unplug one of the dongles each time the project is loaded.
#16
try to rename the second camera. it's fairly forgiving.
