So can older and newer boards (ez-bv4) be used in the same project? The physical configuration of ports is different and I don't seem to be able to get anything in the older board to activate (the newer one works fine).
Thanks,
Daniel
Omron HVC-P2 (Second Camera)
— Windows ARC plugin for Omron HVC-P/HVC-P2: Python-based face/body/hand detection, gaze, age/gender, expressions and recognition; dual-camera support.
Thanks,
Daniel
The older board works on Bluetooth, so your laptop/PC needs a Bluetooth dongle if Bluetooth is not built in. You also need to follow the steps to pair and sync with the Bluetooth board. Did you do that?
Whoops! I'll check. I bet it was still set to network. Daniel
