Serial Terminal icon Serial Terminal — PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex Try it →
Can't Hook Ezb4 Upto ARC
Hey Guys. Here is what I have:
on Board 0, I have a EZB 3. (Working fine on Desktop)(not on Sally Robot.) on Board 2, I have an EZB 4. (not being found on Desktop or Sally robot.)
The ports are: Router 10.0.0.1 Desktop 10.0.0.2 MagicJack 10.0.0.4 EZB 4 (Sally) 10.0.0.6 (proposed, but won't hook up.)
It just tells me it cannot find the EZB 4.
I wish to use the V3 and the V4 together on the W3 Tablet on the Sally robot.
Thanks in Advance
@Mel do the online lessons... particularly this one Connecting your ezb to your PC/network.... If you don't you are going to continue to struggle with this stuff...
Even if I manage to solve your issues I ask you if you would please NOT credit it me for this...
Richard
Can I ask you to please not credit me for this... I'll help you but I don't want the store credit.... Thank you...
ok.
It seems to be related to the wi-fi. I can turn the wi-fi ON on Sally. But there is NOTHING close to an EZB wi-fi signal for me to connect to.
Did you follow the video exactly @Mel?.... Forget Sally... Don't worry about anything complicated right now... just use your main PC's wifi to connect to your ezb4 like in the video... Once you are connected and the ezb webserver is up and running, change your ezb into Client mode... again as the video shows you how..... If you have to watch the video 50 times then do it, there is no shame in it...
  1. First, reset your EZ-B to default settings:
  1. Second, connect to your EZ-B in Adhoc mode directly:
  1. Third, configure your EZ-B to connect to your local network:
Thank You, D.J. , RR. I will try that.
ok, I am hooked up with bluetooth on V3 and wi-fi on V4. But, it tells me it has a limited connection. Only two or three bars.
One thing is, my router is 10.0.0.X and what it is showing is 192.168.1.1.23.
