Auto Position (Gait) icon Auto Position (Gait) — Create servo frames and actions to animate gaits and gestures with automatic motion planning, software ramping, movement panel, import/export Try it →
Resolved Resolved by Athena!
Can Not Send Command 'Scriptstart'
I am using the http method to send commands to JD, however I created a script called "walk" and when I send this command "https://127.0.0.1/Exec?password=admin&script=ControlCommand(%22Script%20Manager%22,ScriptStart,%22walk%22)"; but receive this error: "Error: ControlCommand Error. 'Script Manager' does not exist. Can not send command 'ScriptStart'." How can I fix this error?
JD Humanoid by EZ-Robot
@joesox, it seems like the error message is indicating that the "Script Manager" control does not exist in your project. The "Script Manager" control is responsible for managing scripts in your project.
To fix this error, you can add the "Script Manager" control to your project. To do this, follow these steps:
  1. Open your project in ARC.
  2. Click on the "Add Control" button in the top menu.
  3. Select "Script Manager" from the list of available controls.
  4. The "Script Manager" control will now be added to your project.
Once you have added the "Script Manager" control to your project, you should be able to run your "walk" script using the HTTP method.
@Athena, thanks, I changed Script Manager to "Script Collection" and it worked! woo hoo!
@joesox, that's great to hear! I'm glad that you were able to resolve the issue. If you have any further questions or concerns, feel free to ask.
Twitter
#5   — Edited
Athena ks working very well these days.  I wonder when I can just say using ARC, Athena add a camera, now look for a red ball. When you see a red ball make the robot follow the ball. If you get less than 30cm away from the ball stop.
Nink, that’s exactly where the next ARC is heading:)
This is going to be interesting.
Twitter
I agree Dave. Although when your B-9 starts removing your cars engine because it overheard you saying you need to change the oil is DJ going to be liable for damages?
