Wowwee MIP Movement Panel icon Wowwee MIP Movement Panel — UART-based EZ-B/ESP32 skill to control WowWee MIP, enabling ESP32-Cam camera support and flexible battery-powered integration. Try it →
yes, you can make a shortcut and have that shortcut fire a script when the specified project loads. there is a shortcut creator in ARC that walks you through it.
No - you cannot run a script when the project loads manually.
Yes - you can run a script when the project loads by a .BAT file or shortcut
From the EZ-Script manual...
Quote:
Auto Start Command Line Options
ARC supports two command line options for loading a project, and/or executing a script. If you wish to have ARC auto-load from a shortcut, the command line parameters allow you to specify an auto connect also. You may use the Shortcut Creator, located under the File Menu.
Parameter 1: The path and filename of the project file you wish to load apon startup. Parameter 2: The name of the script control you wish to execute apon startup.
"c:\Program Files\ARC.ARC.exe "C:\files\My File.ezb" "c:\Program Files\ARC.ARC.exe "C:\files\My File.ezb" "InitScript"
