Blinkm icon Blinkm — BlinkM I2C multi-color LED control with slide dials for custom colors; supports SendI2C for custom I2C peripherals. Third-party device. Try it →
Grid settings are on the bug list.
Ok, Thanks:) I can see you guys at EZ-Robot are right on the job! :D
There are no reported bugs or issues with servo speed. What problems are you having?
Hi DJ, I had also mentioned this grid line question awhile ago, so if you are working on it, it would be nice to be able to set to grid lines to a certain setting with a command control or save the settings in a script. That way grid lines that need to be set at other than default settings would automatically adjust when the script is run.
Thanks
The grid lines have been in the to-do list. Nothing ever leaves the todo list
Did you mean to say " nothing ever leaves the todo list until it is done" ? Just kidding. Thanks DJ Go Flames Go!
