Rafiki Front Bumber icon Rafiki Front Bumber — Rafiki front bumper plugin: reads 4 proximity sensors via serial, updates ARC variables, blocks motor movement toward detected obstacles for SLAM Try it →
Camera Object Name
Camera Object Name
How do I reset or clear the last object detected by the camera? The $CameraObjectName variable stays set to the last object detected. This means even when no object is detected or recognised, my script executes incorrectly - instead of saying object not recognised..
I believe it is just a global variable so maybe you can just "zero" it out after detection?...
$object = $CameraObjectName
$CameraObjectName  = ""
Don’t reset the variable. Instead check if there’s a detection. Then check the tracking type that’s detected, if there’s more than one tracking type.
Such as...
if (CameraIsTracking == true && CameraTrackingType == "Object") {
  print(getVar("$CameraObjectName"));
I didn't realise one could change these global variables within script. Setting their value to null after tracking ends solved my problem. Thanks.
