Custom Movement Panel V2 icon Custom Movement Panel V2 — Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives Try it →
Denmark
LinkedIn
Hi,
I just got a Roli robot for some SLAM experiments, but the camera does not work. I was trying the tutorial with the red ball that should be tracked, but the camera showed up as disabled in the on screen log.
The camera is plugged into the EZ-B board in the only correct manner there is possible.
Please, do you know what could be wrong ?
best
Jan Pedersen
#25
@Jop... so sounds like your camera is defective... Refer to DJ's post #22 and contact us....
Denmark
LinkedIn
#26
Hi DJ and all,
Thanks for getting my camera issue settled. I hope I can return with some of my own stuff after 1/2 year of coding and testing. I just started today, on my SLAM algorithm.
Sincerely
Jan Pedersen
#27
@jop Jan, I know this thread is a little dated, but did you every make progress on your SLAM algorithm? Curious because I was looking into doing something similar.
