Neopixel Ring icon Neopixel Ring — ARC UI for onboard computers to control NeoPixel rings via serial: test/run patterns, preview and copy Arduino serial commands, includes sample code. Try it →
Denmark
LinkedIn
Hi,
I just got a Roli robot for some SLAM experiments, but the camera does not work. I was trying the tutorial with the red ball that should be tracked, but the camera showed up as disabled in the on screen log.
The camera is plugged into the EZ-B board in the only correct manner there is possible.
Please, do you know what could be wrong ?
best
Jan Pedersen
Can you see a solid blue led light through the white casing? If not you can try Very carefully removing the camera from the casing... Unplugging it and plugging it back in again... Could just be a lose connection....
Denmark
LinkedIn
Hi Richard,
Thanks a lot, I can see the solid blue light through the EZ-B casing, but it is blinking. Is this ok ?
/Jan
Denmark
LinkedIn
Just another thing: everything else works. All the servos work and the robot can dance and wave
When the camera is working correctly the blue led will be solid... it should only blink momentarily when you first power it on... Are you using the same IP address for the camera as for your EZB?
Denmark
LinkedIn
Camera IP is "EZB://192.168.1.1" and EZB IP is "192.168.1.1:23", so same IP but not port designation for the camera. Could this be the fault?
The strings above are copy and paste from the GUI of the desktop app.
The blue light is still blinking
/Jan
Your IP's are good... Stupid question, but in the camera control did you click start to start the camera?
Denmark
LinkedIn
After restarting the ARC and reconnecting WiFi the blue light is constant (non-blinking).
I did press start to start the camera, but I think the client sw discovers that the camera is disconnected and returns to a stop mode so that the start button is visible again.
The camera is still shown as disconnected. I have tried to mingle the cables with no success
Denmark
LinkedIn
I got a log:
20-02-2015 17:48 - Camera Initialized: EZB://192.168.1.1 @ 320x240 20-02-2015 17:48 - Object Recognition loaded. 20-02-2015 17:48 - Camera Disabled 20-02-2015 17:48 - Camera Initialized: EZB://192.168.1.1 @ 320x240 20-02-2015 17:48 - EZ-B v4 Camera Error: System.ObjectDisposedException: Der er ikke adgang til et fjernet objekt. Objektnavn: 'System.Net.Sockets.NetworkStream'. ved System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) ved EZ_B.EZBv4Video.() 20-02-2015 17:48 - Camera Disabled 20-02-2015 17:48 - Camera Disabled 20-02-2015 17:48 - Camera Initialized: EZB://192.168.1.1 @ 320x240 20-02-2015 17:48 - EZ-B v4 Camera Error: System.IO.IOException:
I would say the camera is broke, ...
