PWM Slider icon PWM Slider — Slider to set EZ-B digital PWM for motor speed or LED brightness; shows duty-cycle, stop button, and board/port selection. Try it →
You can use any third party camera that works with Windows (which should work within ARC too), however you cannot use any other camera that plugs directly into the ezb4...
@handy03.
As Richard has stated, I'm not aware of any other camera that will work plugged in to the EZ-B except for the EZ Robot camera. But if you wanted to experiment, here are the EZ-B v4 camera port specs that tells you what the pins do.
You can experiment all you want but it wont work since the EZ-Robot Camera uses a custom codec.
hi thank you Richard and Steve G for the in put.;)
