Wowwee MIP V2 icon Wowwee MIP V2 — UART interface to hack WowWee MIP with ESP32/ESP32‑Cam or EZ‑B v4 for ARC; hardware UART preferred, configurable power and baud 9600/115200 Try it →
Are you talking about your Lipo battery charger?
Does the battery need charging? If it doesn't then the green light probably wont come on.
If it does, it could be a bad battery. With a multimeter measure the voltage of the battery (from the outer two pins of the balance charger plug). If it shows very low (i.e. under 6v) it may be undervoltage and therefore damaged beyond repair. If it shows over 8v it may not need charging.
I will check that...thanks. You both have the best advice. I truly appreciate it.
Your battery might be charged already. Does the robot complain about a dead battery? If not, the everything is good:)
I think there might be a small short in one of the cables at the site of the connector. It has got an amazing amount of use in the last 3 weeks from our lab students. Just going to replace the connector this weekend. It's good. We really like what you are doing DJ Sures.
