Any Eta On Android?
Any Eta On Android?
Dj,
Trying to decide on onboard computing and before I buy, is there anychance an android EZB is in the near future? By the time I invest in a small touch screen a mini itx, ram, sd card and 12 volt adapter, it's coming up to the same price as some 32 gig tablets. And Android seems to be the os of choice. Some companies said they would be coughing up a Windows 8 version but not until quarter 3 of this year. So any insight into the future would be appreciated!
Will
Hello , android is coming but it will only.have partial support and it is said that.isn't going to be here for a few months. Things like video camera support , web cams , and other things a android tablet doesn't.have capabilities of. I have done a mini pc for around 300 with power supply...
Thanks for replying. I went to Frys today and bought a MSI E350IA-E45. It was on sale for $89. Its 1.6 ghz dual AMD processor. Can accept upto 8 gigs of ram .No onboard wi-fi but bought a usb dongle and bluetooth while I was there. Online I ordered RAM and SSD, to run fast and quiet (and cool). So hopefully this will run EZB with no troubles. Looks to be drawing only 14 watts when running. Thats great for robot power.
Yea I bought a 25 watt tdp ( max draw) AMD dual core 2.2 GHz for mine , 4 gig ram , I haven't measured draw but I bet mine will be low too. Do you know the wattage rating of your cpu? If you feel like still utilizing android , I have Gmote 2.9 and splash remote desktop to use a phone or tablet as a controller. Ofcourse there is the web/browser based remote control too dj recently added in. How much total did you spend?
I think it ended up being close to $300. Do you think that the AMD dual processor running at 1.6 will be powerful enough for robotics? Fast enough? The cpu is a Zacate E350, and the Hudson bridge set, not sure on the wattage. Do you have a handle on a cheap touch screen that i can inbed either in front or acessable through a door. Looking for about 7 inches diaginal. Can be vga or HDMI (only ports available).
If all you have running is ARC or SDK then it is plenty , I know that processor out performs Intel atom 330 1.6 GHz and.that.board was perfect even with the lesser performance
Cool. Yup that's all it will be running. Thanks!
Sooner than you think:) However, @jstarne1 is correct about the performance and configuration ability. I feel over time that ARC on Android will eventually catch up to the Windows version - but that's over time. The graphical processing of these devices appear great... it's the cpu processing that is lacking. The Android OS seems to use a lot of resources, which is surprising. It's a bit less responsive than i expected. The Apple iOS version we have is fantastic responsive.
The hold-up right now on finishing the application is due to a bunch of events we are attending and sponsoring. Sorry:) But it's for the good of mankind! hehe
Indeed it is. Good info, very interested in a Apple IOS version....like the IPAD? Crappy they still have not added a usb port, or support flash....
Any chance you could give us insight into the path for EZB, say the next six months to a year? Where do you want it to go from here?
Will
