Touch Path icon Touch Path — Sketch paths with finger or mouse and set turn/move speeds; interactive, educational demo of timing-based, sensorless robot navigation and limits. Try it →
Yes, if you mean a full blown win10 tablet like an Acer Iconia A4
Software options can be viewed on the software page. There is a button on the top menu of the website titled Software. Press the software button and all software options are available: https://synthiam.com/EZ-Builder
Mobile options are on the software page under the mobile tab. Android and iOS are supported. The manual for the mobile tab will display all supported controls
@dj On the mobile tab it lists a Feature called Autonomous Self Navigation
What is that referring to?
Thanks, Frank
Referring to that you can write a script for autonomous self navigation using sensors and cameras. You can find out more about EZ-Script in the learn section under Activities.
@westies I am running ARC for Windows on two small devices with Windows 10:
Toshiba Encore 2 10" tablet
Intel 2nd Generation Compute Stick BOXSTK1AW32SC
Regards, Frank
England
Thanks for your help. Does running the ARC include actual programming which is only possible on laptop or pc. i would like to programme from the tablet.
If your tablet is running Windows, you have the same capabilities as running on a laptop or PC with Windows
I think what may be confusing you are the restrictions listed for the mobile version of ARC which are for IOS or Android tablets.
@westies If your tablet runs full windows 10 then you can do everything that ARC offers on it... That includes what you referred to as "programme" (albeit without a mouse and keyboard it will hamper you a little).... As long as it is windows 10, it doesn't matter whether you have a tablet , laptop or desktop, ARC will be fully available... The only limitations are on mobile devices like IOS and android....
