Hello! I don't seem to be able to find the dimensions of the servos (length, width, height, shaft diameter). Does anyone have that information? Thanks!
AB2012
Train Vision Object By Script
— Train camera vision objects via controlcommand(), attach camera, start learning, monitor progress, and return object name for scripts.
Any specific make or model? Or are you specifically asking about the ones in the EZ-B complete kit?
I've found that every website where I've looked to buy servos from will give the technical data sheets which have the dimensions on them.
Generally a standard servo is roughly 55.5 x 20 x 42mm but I assume different manufacturers will have slightly different dimensions...
Sorry, I should have been more specific. Yes, I am asking about the ones in the EZ-B kit.
Servos:
EZ-B:
Thank you!
