Hitachi-LG LDS Lidar icon Hitachi-LG LDS Lidar — Hitachi-LG LDS 360-degree LiDAR driver streaming scans into ARC NMS for obstacle detection, SLAM use, Arduino hookup, config options and variables. Try it →
For my upcoming project(no hints, but cardboard is a material) I need 2 12v dc motors to be run off the h-bridge in the store, which means the max motor amperage is 2.5Amps.
Size isn't big but the robot will be mid-sized. 5 pounds or so of torque per motor if possible.
If it could have a wheel that would be awesome!
Anyone who can link me to some motors will be put on the credits list for the future bot.
Thanks guys!
Servocity.com has a few gearmotors. See if any will work for you.
ServoCity precision gearmotors
Cheaper but lower torque ones are here since you're probably going to be light weight.
Consider getting a Roomba "for parts" , it will come with a couple of drive motors rated at 12volts.
Robot-doc, would they be enough?
Troy, I like the site but I priced the stuff needed and it's almost $100.
Any other sources are appreciated.
@Technopro Those will work, but 300rpm is a tad fast I would think... If you pwm down it won't have any torque left... It is a motor definitely meant for high speed.. I like motors of around 100rpm on the output shaft... A Roomba is close to that (100rpm or so) or even possible a little less...
@Technopro, No problem. I know it can be pricey.
