Camera Video With Ezb 3
I have a wireless video camera that has a receiver on usb port.I am using EZB version3 .Camera comes up great with video software that came with camera,but i get no image when i select OEM video device from camera device list. Realtime video no image .Tried different resolutions no video when i hit start?
rb550f, Is there some way you can remove the software driver that came with your camera and let windows find its native driver when you plug in to the USB? I have heard that some drivers can cause problems. Steve S
Are there any messages in the debug window when you press the START button on the camera?
at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo) at .(IAMStreamConfig , String , Object ) at .(Size ) at EZ_B.Camera.StartCamera(ValuePair videoCaptureDevice, Control processedPreviewControl, Control realtimePreviewControl, Int32 captureWidth, Int32 captureHeight). Resolution: 320x240
Windows 7 not able to install without oem driver.
Sorry, press the COPY button on the debug window to get the full message. It appears the default native resolutions are not supported on that camera - but I can't be certain without the full message.
It could be a camera from some strange manufacture for PAL resolutions or something strange:)
Here is the debug statement copy. 6/10/2014 4:24 PM - Camera Disabled 6/10/2014 4:24 PM - Camera Initialized: Chicony USB 2.0 Camera @ 320x240 6/10/2014 4:24 PM - Camera Disabled
6/10/2014 4:25 PM - Error Initializing Camera: System.Runtime.InteropServices.COMException (0x80004005): Error HRESULT E_FAIL has been returned from a call to a COM component. at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo) at .(IAMStreamConfig , String , Object ) at .(Size ) at EZ_B.Camera.StartCamera(ValuePair videoCaptureDevice, Control processedPreviewControl, Control realtimePreviewControl, Int32 captureWidth, Int32 captureHeight). Resolution: 320x240
I started with camera on laptop..works..Then i tried OEM video device camera and tha is the statement i copied from debug
I still need assitance on getting video for this camera?
Sorry, it appears that camera is not compatible with standard video resolutions - ARC supports only standard video resolutions
