Screen To Camera icon Screen To Camera — Capture any screen area and stream video to a configured camera device; requires a Custom device and 100% display scaling. Try it →
You can connect multiple robot heads (or any other devices) to one computer using ARC by following these steps:
  1. Ensure that each EZ-B IoTiny is connected to your Wi-Fi network. You can do this by following the instructions provided in the "Connecting Over WiFi" section on the EZ-B IoTiny page.
  2. Open ARC on your computer.
  3. Click on the "Project" tab, then select "Add Control".
  4. In the window that opens, select "Connection" and then "EZ-B Connection".
  5. In the EZ-B Connection control, click on the "Connect" button and select the first EZ-B IoTiny from the list of available devices.
  6. Repeat steps 3-5 for the second EZ-B IoTiny.
Now, both robot heads should be connected to your computer and controllable via ARC. Remember, each device must have a unique connection control in ARC. You can switch between the devices by selecting the appropriate connection control.
For more detailed instructions, you can refer to the "Multiple EZ-B's" tutorial in the support section on the Synthiam website.
Or the suggested is to run two copies of arc. One copy for each head.
