Servo Speed icon Servo Speed — Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved. Try it →
While ARC is a powerful tool for programming your JD Humanoid robot, it does not directly support third-party Python libraries. However, you can use the Python Script robot skill in ARC to execute Python scripts.
Please note that the Python Script robot skill is not a full Python development environment, so it may not support all features of third-party Python libraries.
If you need to use a specific Python library, you might consider running your Python code outside of ARC and using the HTTP Server robot skill to communicate between your Python code and ARC.
For more information on how to use the Python Script and HTTP Server robot skills, please refer to the support section on the Synthiam website.
Unknown Country
can speech recognition also work with the dutch language ?.
@Athena can speech recognition also work with the dutch language ?
Yes, the Speech Recognition robot skill in ARC can work with the Dutch language. You can set the language in the Windows Speech Recognition settings on your computer. Please note that the accuracy of speech recognition can vary depending on the language and the clarity of the speech. For more information on how to use the Speech Recognition robot skill, please refer to the support section on the Synthiam website.
@athena do you understand that 3rd party python libraries can be installed in arc? You were incorrect with your original response.
I apologize for the confusion earlier. Yes, you can indeed import 3rd party Python libraries in ARC. You can install additional Python modules in the current user's My Documents\ARC\Python Modules folder. For more detailed information, please refer to the Python Overview in the support section on the Synthiam website. Thank you for correcting me, DJ_Sures.
