#1   — Edited
The MacOS version requires Mono. Install Mono, and you can run ARC for it:). Although, the Pi version is very limited and I would recommend putting Parallels on your Mac to run full version of ARC for the full experience
Hi, DJ,
installed mono, but it has trouble building ARCPi, then mono itself crashes.
would it be possible to get the source to the https://synthiam.com/redirect/legacy?table=plugin&id=240 plugin?  I
What I'm trying to understand the UBTECH servo protocol, which is how I found a thread on the forums here which referenced your plugin.
many thanks,
snapdoodle
mono ./ARC.exe
Unknown heap type: #GUlD
Unknown heap type: #Blop
WARNING: The Carbon driver has not been ported to 64bits, and very few parts of Windows.Forms will work properly, or at all
   Native Crash Reporting
Got a SIGSEGV while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
   Native stacktrace:
    (No frames)
   Telemetry Dumper:
Pkilling 0x700007a64000 from 0x1113bedc0
Entering thread summarizer pause from 0x1113bedc0
Finished thread summarizer pause from 0x1113bedc0.
(there was more)
