HT16K33 Animator (8X8) icon HT16K33 Animator (8X8) — Control for Adafruit 8x8 LED Matrix (HT16K33) via EZ-B v4 I2C; creates animations, supports module initialization and EZ-Script control. Try it →
Yes Or No Script
I want to make my robot able to choose yes or no by itself. I made this script but theres something wrong with it because I can't save it.
$Yes=0
$No=0
$choice1 = GetRandom(0,1)
If $choice1= $Yes
   Controlcommand("script manager", scriptstart, "Yes")
Else If $choice1= $No
   Controlcommand("script manager", scriptstart, "No")
ENDIF
Yes and No both equal 0, the script will only either say Yes or end.
Also, it should be ElseIf not Else If.
Good practice is to use a 0 for off, false or no and 1 for on, true or yes.
Try;
$No=0
$Yes=1
If $choice1= $Yes
ElseIf $choice1= $No
ENDIF
That said, the Yes & No variables are redundant really, I'd just do this;
If $choice1= 1
ElseIf $choice1= 0
ENDIF
Sorry, I didn't pick up on that error.
IF($choice=1)
ElseIf($choice=0)
is the correct syntax, you forgot the brackets.
I tried this but it just kept on going. it never stopped.
What do you mean it never stopped? There is no loop in the code so it would get through the IF and would stop...
FYI, the code should be (for anyone who searches and for you if needed)
IF($choice1=1)
ElseIf($choice1=0)
EndIf
While it's not required since the code doesn't go anywhere after the EndIf you could add in some Halt() commands to ensure the script ends...
IF($choice1=1)
  Halt()
ElseIf($choice1=0)
  Halt()
EndIf
And to make it that little bit better and add in confidence, like @MovieMaker has been wanting for a while you could do something a little bit like this, where $confidence is determined by the question asked in another script;
# Get a response value
$response = GetRandom(0,100)
If($response <= $confidence)
  ControlCommand("script manager", scriptstart, "Yes")
Else
  ControlCommand("script manager", scriptstart, "No")
EndIf
Or if you wanted to use the routine within a script rather than to call a yes or no script;
# Some script...
#this could be read from a file or database possibly
$confidence = $activity1likelihood
Goto(decide)
If($decision = 1)
  # Carry out the task
Else
  # Refuse to carry out the task
  SayWait("No way, I dont want to do that")
EndIf
# More script
# End of main script
Halt()
# Decision routine
:decide
# Check the response against the likelihood or confidence
  $decision = 1
Else
  $decision = 0
EndIf
Return()
# Other routines
Or if you want the decision code to be a separate script you can pause the main script like;
ControlCommand("script manager", ScriptStart, "decide")
$decisionscriptrun = 1
WaitForChange($decisionscriptrun)
If($decision = 1)
Else
EndIf
# More script
And the decision script;
  $decision = 1
Else
  $decision = 0
EndIf
$decisionscriptrun = 0
If it's not obvious the scripts above still need some work and fine tuning for whatever the task is and however the confidence and likelihood is fetched. But it's the bones to put the meat on.
I think I got a little carried away but I needed a short break:)
I have experimented with this top one but it doesn't seem to work. it always chooses no.
  ControlCommand("script manager", scriptstart, "Yes"Winky
Else
  ControlCommand("script manager", scriptstart, "No"Winky
EndIf
What can I do to fix it?
Where's it getting it's confidence from?
Provided the random number generated for the variable $response is less than it's confidence it should answer yes. Set $confidence at 100 and try it.
$confidence = 100
Else
EndIf
That will always answer yes.
You can also add the variable monitor control and look at what $response is when it's being picked. If it's always answering no it is always picking a number higher than $confidence
