did anyone get wifi to work?it would be nice to connect pc to ez by entering an ip address instead of com port
could this be coming in the future eyeroll
PWM Slider
— Slider to set EZ-B digital PWM for motor speed or LED brightness; shows duty-cycle, stop button, and board/port selection.
no one got wifi to work? it it possible to connect ezb to router direct?no blue tooth
You will need extra hardware like a wifi to serial module to make this work. Then no problem
On the website there is a Tutorial link from the top menu. You will find hardware and software assistance. The question you are looking for is: https://synthiam.com/Tutorials/Hardware.aspx?id=22
:) I should do a video someday showing how to wire it up
that is the link i used but can not get it to work.I did get my wifi settings setup (i think)but that is it.A video would be great
welp DJ if you plan on doing so you might want to mention about how to get the unit out of auto mode if it happens to be shipped in such mode. I had to download arduino for the serial terminal, hyperterminal didn't work and neither did a custom c# setup. There are other terminals I'm sure will work but I was looking into the atmega328 so.
