Why Doesn't This Script Work Any More?
I have just switched over to the new 3 port Ultrasonic Sensors and this script will no longer work. It's the one I used for the 4 port Ultrasonic Sensor. The script always Prints 2 no matter how close I get an object to the sensor.
$Center = GetPing(D11,D11)
$close = 40
:start
if($Center < $close)
print(1)
else
Print(2)
endif
Sleep(2000)
Goto(start)
I have tried a 4 port sensor and it won't work either. Was there a change that I missed?
@bhouston,
Try this:
$close = 40
#--- loop block ----
:start
#inside the loop
if ($Center < $close)
  print(1)
ELSE
  Print(2)
endif
Sleep(2000)
Goto(start)
I don't have a 3 wire Ping, the 4 wire is working.
:loop
# D21=Trigger=White
# D22=Echo=Green
$distance=GetPing(D21,D22)
print("Distance: " + $distance)
Sleep(1000)
Goto(loop)
Thanks Pedro, that worked. Copying and pasting got me on that one.
